My lt 80 transmision wont pull when wet is it the belt?
Old Aug 26, 2004 | 12:55 PM
woosh's Avatar
Default My lt 80 transmision wont pull when wet is it the belt?
I have two 87 lt 80 quads both are stock and both hate it when i go thru a lot of water they run fine but they wont move but very slowly at the very bottom of the rpm range they have done it a few times now and seem to be fine when they dry out although it sucks pushing them back home so if someone knows how to fix this problem I would like to know
Old Aug 26, 2004 | 02:57 PM
Jibrille's Avatar
Check your belt cover seal, even buy a new one if you must, it happens to a couple guys i know, it is because their case wasn't sealing properly.
Old Aug 27, 2004 | 01:48 AM
quadduck's Avatar
there is a drain bolt at the bottom towards the back of the belt case. Or you could have a bad clutch or glazed belt but I would bet your getting water in there. Also I would lube up the clutch rollers if you have been riding them through water.
Cummins Driver
Sep 11, 2019 01:22 PM
SDR-II
Sep 29, 2015 01:06 AM
toonces
Jul 31, 2015 09:27 AM
Mikesohio
Jul 26, 2015 10:51 AM
trouttracker
Jul 20, 2015 11:54 AM
