Paddle Question.... Z400
Old Sep 21, 2004 | 02:09 PM
95eclipsegsx's Avatar
Default Paddle Question.... Z400
I am going to be buying a set of used Sand Geckos sizes 21X11-10 for my 03 Z400 at a good price. Note: I am on a short budget..
Anyways, I was just wondering, for that size of paddle tires, What size rims will I need in order for it to fit on my Z400??
Sorry, i'm new to this. I have search, but no luck.
Thanks for the help.
Old Sep 21, 2004 | 02:52 PM
droz's Avatar
an 8, 9, or 10 inch wide rim will be fine.....id lean more for 9 if u can find it and just make sure its a 10 inch diameter
Old Sep 21, 2004 | 02:54 PM
so, a 9 inch wide and 10 inch diameter should do it? Awesome, i'll keep on a look out for a used set if I can find one.
Thanks!
Old Sep 21, 2004 | 03:25 PM
droz's Avatar
yup that will work
Old Sep 23, 2004 | 02:27 AM
mucky's Avatar
with a 21" high tire you might have to regear
stock gearing is 14/40 with 20' rears and with 21" it might be a little slower
if you want to keep the low end torque you need to go 13/40 or 14/41
Old Sep 23, 2004 | 07:57 AM
QuadN00b's Avatar
I have 20" sand stars and I also dropped to a 13t sprocket. It's good all round for playing in the sand. I'll probably put it back to a 14 once I get back and trail ride again.
Old Sep 23, 2004 | 08:29 PM
2112's Avatar
Gecko's are ok i have some but the way to go is maxxis 4 snow 23 in. i wise i'd got those. Also you dont have to regear.
Old Oct 1, 2004 | 12:51 AM
mucky's Avatar
if you stay stock size on the rear paddles you dont need to regear but if you get taller tires
you need to regear or you lose torque on the bottom end
NewGuy2481
Oct 6, 2015 05:54 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
1ArmBandit
Sep 8, 2015 08:59 PM
Jul 15, 2015 02:07 AM
