z250
Old Oct 4, 2004 | 04:39 PM
TomZ250's Avatar
Default z250
im having a problem with my z250 brakes. They are always sticking. Ive tried wd40 wont work. They are my rear brakes and they always squeek and drag but when i get goign there bettter. Anyone know the soultioin to fix them?
-thanks tom
Old Oct 4, 2004 | 06:30 PM
z250freak's Avatar
Default z250
Is their mud built up inbewteen them. Maybe your rim is bent and its rubbing.
Old Oct 4, 2004 | 06:56 PM
CHEWBACCA's Avatar
Default z250
that happened to me too. take apart the whole drum brake andclean it out and grease it
Old Oct 4, 2004 | 07:34 PM
TomZ250's Avatar
Default z250
they always squeek and its hard to drive at first. its the little thing that is connected to the two breakes and when i pull it backwards it rolls.?
Old Oct 4, 2004 | 08:47 PM
styelz's Avatar
Default z250
if its the back then theres 2 turn noobs at the end of the brake lines, if u have titen them they might be too tight and might be causeing the brakes to be rubbing constantly, make sure that is not the problem, and if u ajust it thres 2. Ones for the hand brake and the others for the foot. If its not the problem put it back to the original positionn.(count how many turns you do on each)!
Old Oct 4, 2004 | 08:54 PM
TomZ250's Avatar
Default z250
thanks but ive know that and tried it lolol well there really squeeky and they always lock up when i start out what should i do?
Old Oct 4, 2004 | 10:24 PM
styelz's Avatar
Default z250
well if thats not the problem i think u should do what CHEWBAKA said and then tell us how it went! But make sure after u clean it all off put some grease back on!
Old Oct 6, 2004 | 10:54 PM
GTFZ250's Avatar
Default z250
DUDE!!!! No wd-40 on the pads. If u put wd-40 on the brake pads or sprayed the caliper then ur pads are shot. wd eats the brake pad material. Please tell me that I missunderstood....
Old Oct 7, 2004 | 06:11 PM
TomZ250's Avatar
Default z250
no no no lolol i'm not that dumb, the back part where it was sticking
Old Oct 8, 2004 | 09:04 AM
GTFZ250's Avatar
Default z250
oh good Just making sure u didnt make that very stupid mistake
