wont start cold
Old Oct 5, 2004 | 02:48 AM
jhvmat's Avatar
Default wont start cold
I have a z400 stock. I have to pull start it cold. put a manual choke on it. cleaned the jets. dont have air leaks. any help please.
Old Oct 5, 2004 | 03:40 AM
nosliw's Avatar
any mods?
Old Oct 5, 2004 | 04:09 AM
jhvmat's Avatar
no mods all stock thats why so lost on this one
Old Oct 5, 2004 | 10:02 AM
warrior226's Avatar
put the petcock on "prime" for a minute before you start it, then switch it to "on" after you start it.
Old Oct 6, 2004 | 11:16 AM
jhvmat's Avatar
thank you will try and let you know
Old Oct 6, 2004 | 03:40 PM
hondabuster's Avatar
How long has it been since the valves were adjusted?
Old Oct 11, 2004 | 08:51 PM
jhvmat's Avatar
valves were adjusted 5 weeks ago when in shop for this problem. still wont start cold tried the prime for 1 min still wont start
Old Oct 11, 2004 | 08:59 PM
Scooter86's Avatar
Knows Old ATV Questions!
OK, living in FL, just how cold are we talking here? When it gets really cold you can get that problem if you haven't rejetted the carb. Have you
checked battery output?
Old Oct 11, 2004 | 11:03 PM
jhvmat's Avatar
engine at room temp 80 degrees. it seems to crank fast enough, but will check that.
Old Oct 12, 2004 | 02:58 PM
Once its been running and warmed up...if you turn it off, will it restart good then?
Have you tried a new spark plug?
Id think at 80 degrees, you wouldnt even need the enrichener, to start. Hows the air filter...clean and reoiled? I know you said it was stock...but the air box lid is still on?
