z400 6 months old, lost power and top end bogs????
Old Oct 7, 2004 | 11:25 AM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
Default z400 6 months old, lost power and top end bogs????
get your 20 hour service (valves and so on)
Old Oct 7, 2004 | 12:40 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Isn't warranty 1 year? So isn't it still on warranty??? If so, make it the dealers problem.
Suzukis are famous for having problems with the fuel petcock, which is run off of vacume from the carb. Put it in on PRI, and see if the problem goes away.
Old Oct 7, 2004 | 12:59 PM
asfasasu3's Avatar
If it idles OK but cuts out when on the throttle, it sounds like water in the gas. All gas has it. When sitting for a while, the water can settle in the bowl. Try draing the bowl and let gas run though it for a second or two and then try it again.
Old Oct 7, 2004 | 01:34 PM
YZLTZrider's Avatar
I have tried both of those things and the warranty is up, 2 weeks after the 6 months..isnt that always how it works.[img]i/expressions/face-icon-small-confused.gif[/img]
Old Oct 7, 2004 | 03:39 PM
  #15
Red Rider
My rear shock blew a couple of weeks after it went off warranty, but good excuse to get some aftermarket ones!
Old Oct 8, 2004 | 12:11 AM
  #16
mucky's Avatar
check your carb. it happened to me
the main jet fell out . it iwould idel fine but
once you gassed it it lost power, pulled the carb
and found the jet in the bowl
Old Oct 10, 2004 | 11:14 PM
  #17
YZLTZrider's Avatar
Thanks for the help, LTZ400guy nailed it on the nose. I cleaned the carb and it runs like new again. Time to pipe it!!
scram5050
Aug 30, 2024 01:39 PM
mtdewmn
Jan 19, 2017 12:13 PM
cody500ho
14
Aug 14, 2015 05:03 PM
Jul 15, 2015 02:07 AM
Scottma518
Jul 10, 2015 12:42 AM
