the ones that really mud!!!
Old Oct 18, 2004 | 04:19 PM
king700's Avatar
Default the ones that really mud!!!
what do you do for the radiator....usally at the end of the day my temp light comes on..even when i drive through mud puddles the radiator gets clogged..any tricks or help would be good..i have been racing sence i was 6 and im 26 now..i always had racing quads not 4x4..but these are awsome..
Old Oct 18, 2004 | 04:49 PM
Antalope's Avatar
I mounted my oil cooler on my front rack. I know of others that have done that with their radiator. You can put a shield in front of it that might help, Of course, not if you burry it.
Old Oct 18, 2004 | 05:13 PM
king700's Avatar
if you put a shield in front of it..it would run to hot..because its not getting cool air flow...
Old Oct 18, 2004 | 05:18 PM
Snowwolfe's Avatar
I found out what works the best is to make sure you clean it as well as possible before you take it back out. The mud bakes onto the cooling fins and is difficult to remove. Using a garden hose with a nozzle (not a high pressure washer) repeatedly wash it out. Spray it till you think it is clean and then wait about 10 minutes to permit the water to soak thru to another mud layer and hit it again. Do this till no more dirty water drains off. It usually takes 4 or 5 attempts to clean it completely.
Old Oct 18, 2004 | 05:21 PM
Antalope's Avatar
You would want to put a couple of inches in between the shield and the radiator.
I have a shield on mine and so do about 6 or so of my riding buddies. Here's a couple of pics.
http://216.77.133.136/images/grizzpi...rackrear2g.JPG
http://216.77.133.136/images/grizzpi...eronrackrt.JPG
http://216.77.133.136/images/grizzpi...onrackrear.JPG
http://216.77.133.136/images/grizzpi...rightfront.JPG
I'll try to find some more pics. If you have a good fan the space can be about 1-1.5 inches
between the shield and cooler.
Old Oct 18, 2004 | 06:24 PM
king700's Avatar
holy crap dude your not messing around...um i just bought a 2005 kingquad 700 and i dont think i could do that to my quad..i dont go throught the mud like that..i mean just a few mud puddles and a little of mud..not 4 feet of mud..thank you for trying to help..i was just wondering if you could put a screen infront of the radiator or something so the mud doesnt stick to the radiator...to bad they dont make a sprayer like the windsheild wipers have on a car..hummm
Old Oct 18, 2004 | 06:52 PM
Antalope's Avatar
a screen or sheet metal will help, no doubt. just make it strong enough so that it won't get torn up very easy. If you mount it at couple of inches from the radiator it can still work. The fan will be able to pull all the air it can through a 1.5 to 2 inch gap all the way around a piece of sheet metal. Most of those fans can't move but around 300cfm. The gap would be plenty large.
What i have there i can take off and mount in the stock location. I used some adapters on the hose so i didn't have to cut the factory hose ends, If i wanted to use the factory cooler again. I would mount the current cooler in the stock location and all would be ok.
Old Oct 19, 2004 | 12:53 AM
MonZooki's Avatar
Get a small bilge pump...keep it with you...when you come to a clean creek wash it out on the trail...just throw the suction end in the stream...and spray the water out the front into the radiator! Depends how bad you have the problem, if you can't get back to the truck without overheating...it is handy to have!
Old Oct 19, 2004 | 01:34 AM
Curls's Avatar
Antalope
Impressive set up. I noticed a temp gauge what does your quad usually run at?
Does it ever still overheat?
Old Oct 19, 2004 | 08:19 AM
Mudrush's Avatar
My bad
