Painting the Motor
Old Oct 22, 2004 | 12:57 PM
bombest's Avatar
Default Painting the Motor
I am in the middle of rebuilding my quad. I have a 89 lt250r and Im not sure what to do with the motor. Is there special paint for aluminum and high heat parts like this... where could I find it and what is the name of it?
thanks for help.
Old Oct 22, 2004 | 08:24 PM
LT2Fiddy's Avatar
im in the middle of my rebuild too...and i also need to know the answer to the exact question...my frame and other stuff is going to be powdercoated, but the engine obviously cant be done without serious teardown. Should the same paint be used on the radiator?? Please help us...
Old Oct 22, 2004 | 08:45 PM
ZillaRider02's Avatar
I have used the PJ-1 brand of paints with good luck. We painted an LT500 engine with the Suzuki Blue and it came out GREAT! It is an aerosol rattle can and fairly inexpensive (about $5.00 a can). As far as radiator paint, I'm not 100% sure. Radiator shops use a different paint that I believe is thinner than most paint. Hope this helps.
Old Oct 22, 2004 | 10:58 PM
mucky's Avatar
you can get all kind of engine paint in lots of colors
and you can paint the radiator as long as you dont block the cooling fins
we do it all the time just make sure you primer it first
dont use primer on the fins of the radiator give it a lite coat of paint
Old Oct 22, 2004 | 11:18 PM
mucky's Avatar
thanks. lots of work and $$$$
Old Oct 22, 2004 | 11:20 PM
LT2Fiddy's Avatar
so basically you can use regular paint on the engine, but do you primer it?? because from whats chipped off mine it doesnt look like its primered...
Old Oct 22, 2004 | 11:39 PM
mucky's Avatar
$18k and it took almost a year to do
Old Oct 22, 2004 | 11:43 PM
mucky's Avatar
they have paint thats called engine paint its made for high temps
and primer helps stick the paint to the metal. thats why cars are primered first
to help the paint from coming off. the metal you paint has to be clean
no oil or dirt
Old Oct 23, 2004 | 02:01 AM
LT2Fiddy's Avatar
im sandblasting everything thats gonna be painted myself...most everything is gonna be powdercoated though...where is the engine paint available at??
Old Oct 23, 2004 | 11:43 AM
mucky's Avatar
any auto parts store should have it
