jetting a eiger
Old Oct 25, 2004 | 02:18 PM
king700's Avatar
Default jetting a eiger
does anyone have very good starting points on jetting a 2004 eiger..my father-in law got a eiger with 26 in mudlights and he wants to re jet and put a airfilter in it. a little help here would be good..
Old Oct 25, 2004 | 07:33 PM
DaFoo's Avatar
http://www.quadworks.net/
They make a stage 1 kit for the Eiger! I did it, and it really helps!
Vroom!
I have a stock one to for my wife, so if i get a chance I'll do a 0-40 run with both machines and record the difference.
Old Oct 25, 2004 | 11:51 PM
aksafari's Avatar
Before I 'upgraded' to the Vinson carb, I went with the Keihin 134 jet in my Eiger. Seemed to make a noticeable difference. Especially in the low end and at start-up.
From the factory, it was fairly cold blooded, and seemed to lack poop off the throttle.
Old Oct 26, 2004 | 12:48 AM
DaFoo's Avatar
The quadworks kit comes with all the jets, plus a modded needle. Everything you'll need from stock exaust to modifed from 0 to over 6000 feet.
The needle is adjustable with special washers so you can set it to the right elevation as well. The jets are Dynojets and I think I got like 9 or 12 of them all for different altitudes. One point I will make is even though you get a lot more power it also makes you machine more elevation sensitive than stock. So you should alway carry the spare jets around for different heights.
It also comes with a high flow air filter. All I can say is my Eiger really gets up and moves now. It felt a lot like my dads Artic Cat 650 at least till about 30.
I was truly shocked at how much it helped. I will also suggest you have some mechanical know-how, not that it's hard, but you are pulling the top and the bottom off the carb to change the needle and jets.
I was able to do all the work without taking the carb out. I was able to rotate the carb so the top was on the right side, and the bowl was on the left. I would also recoomend you have someone help as it makes it easier.
[img]i/expressions/face-icon-small-happy.gif[/img]
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
