axle bearing seal question
Originally posted by: terd
i don't have a manual in front of me(i am at "work")and i noticed that the pivot works seals have a ridge one one side,does this raised area face the bearing or away from it
i called pivot works and they told me to install with the ridge facing out[img]i/expressions/face-icon-small-shocked.gif[/img]
no biggie,i put in a grease fitting between the adjuster studs so i can fill up that mo fo up with grease..i also removed the bearing seals that face inward so grease can get into the bearing
