Black rims-white z250
i just painted mine black.it looks real nice(yellow Z400).i used krylon fusion without sanding or priming(the directions on the can said you didnt need to)anyhoo i am experementing with this, and if it chips i will try primer.i think keeping the paint from chipping will be difficult.
i will geet pics up soon.
i did on the front,the rear i left on and put the quad in first gear and then painted,the paint came out awsome(no runs)but the down side is black hub and nuts,so i got 5F5 paint remover and a toothbrush to remove it.later i will repaint the hub blue.i noticed a small chip near one of the lug nuts.so i need to start over and sand,prime with a good primer,then repaint.if that doesn't work than i will get hypers!!!!
