squeaking noise
Old Nov 6, 2004 | 12:23 AM
ZillaRider87's Avatar
Default squeaking noise
when i move the zilla in neutral or with clutch in by pusing it, i can hear a squeaking noise coming from the rear, could it be my bearings?
Old Nov 6, 2004 | 12:59 AM
mucky's Avatar
it could be bearings or your brake rotor making all the noise
Old Nov 6, 2004 | 10:09 AM
ZukZilla550's Avatar
Brake noise,I get that in mine.
Old Nov 6, 2004 | 10:59 AM
is it nothing i should worry about or how should i get it fixed
Old Nov 6, 2004 | 12:46 PM
I tried to fix the noise,new brake pad's,rotor,caliper,etc.nothing worked.I only hear it when the engine's off.It has'nt hurt anything on mine,check it over to make sure your not hurting anything.
Old Nov 8, 2004 | 12:15 AM
22Hornet's Avatar
My Ozark was doing the exact same only on the right front. Pulled the caliper off and in the caliper cup was a bunch of grass and dirt and crud. Dumped it out, and the noise is gone haven't ridden it yet and applied the brakes a bunch but I bet the crud was holding the pad against the rotor.
Old Nov 8, 2004 | 07:07 AM
Jibrille's Avatar
Play with some brake cleaner. [img]i/expressions/face-icon-small-happy.gif[/img]
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
kbazzy
Sep 26, 2015 11:26 AM
Canamaniac!
Sep 4, 2015 06:44 PM
