Eiger Backfires?
Old Nov 7, 2004 | 12:47 AM
chipdog4's Avatar
Default Eiger Backfires?
My friend's dad owns an 02 Eiger Auto that he graciously lets us borrow to ride around his gravel pit. Every once in a while after running wide open for a spell, it starts running like the choke is on. It will stutter and stall, and I actually had to turn the choke on to make it back. The first time it happened, it was right after it was started and it seemed like the choke cable was stuck, so I fiddled with it and it came out of it.
His dad just said it started really hard the other night, too.
Any Ideas? Carb? Timing?
Oh the belt seems to be slipping every now and then too. Is this a common occurence?
Thanks Guys
Old Nov 7, 2004 | 12:53 AM
pendejo's Avatar
Strange, is the bike stock? Ever had this problem before? Remove and clean the carb and air filter, see what happens.
Old Nov 7, 2004 | 01:06 AM
chipdog4's Avatar
Stock right down to the original oil yet.[img]i/expressions/face-icon-small-shocked.gif[/img] It only has about 200 miles on it.
This just started within a month or so.
Could dirty gas cause it? They have old gas cans at the pit and I wouldn't be surprised if there's dirt in the cans.
Old Nov 7, 2004 | 01:12 AM
pendejo's Avatar
Well, dirty gas in tank, dirt gets sucked into carb, jetting's off because of dirt and now bike won't run. Clean the tank and carb and while you're at it, new plug too!
Old Nov 7, 2004 | 01:44 AM
quadduck's Avatar
Some of the 02 eigers had loose carb boots that allow you suck in some crud, clean out the jets.
Old Nov 7, 2004 | 01:53 PM
rolsmojave3's Avatar
mine does this too but i cleaned the carb and put a fuel filter on it but it still did it...i dont know if it gets starved for gas but now i run mine on the prime position all the time now and it hasn't happend yet but i havnt' riden a lot
Old Nov 7, 2004 | 10:41 PM
quadduck's Avatar
I own 4 suzukis and I run them all on the prime position.
Old Dec 4, 2004 | 10:04 PM
Chasmo's Avatar
I have an '03 Eiger and experienced these same spitting and puking problems.
My solution was:
A. Drain float bowl...there was water and small debris in the float bowl due to lack of fuel filter. There is a drain screw on the left side bottom of the float bowl.
B. Install an inline fuel filter...$3 to $10 depending how exotic you get.
C. Reroute the vent line under your seat...it has a tendency to get pinched.
If you run on "PRIME" ...you do not have a reserve in your tank. It can be a long walk
Old Dec 7, 2004 | 04:13 AM
quadduck's Avatar
Thats why I top off before I ride. I am use to mx bikes with no reserve.
Old Dec 7, 2004 | 05:02 PM
RidinLCWA's Avatar
Please explain the benefit of running the quads in "prime" position. My understanding is that prime allows a free flow of fuel through the carb. My Vinson was running a bit funny. Then I noticed it had somehow been switched to prime. When I put it back to the normal position, performace improved.
