Intake ? on z450
Old Nov 16, 2004 | 08:10 PM
suzukiyamahaman's Avatar
Default Intake ? on z450
I put a 39mm fcr carb on my z450 (yosh motor )
What's is anyone using as a a rubber boot on the cylinder to the carb.
I tried to use the stock on that came with my z but the carbside of the boot is to small I heat it with a heat gun and sretched it and got it on and it came off after a couple of partices.
So I tried a boot off a yzf 450 it fit the carb good but the the cylinder side of the boot was to alittle to big . I put a bigger clamp on it and went practiced one day and it did fine and though a race this weekend I went and practiced sunday at a mx track and the clamp slide back and tore a hole in the boot.
Someone has to know something better that will work and know someone who makes something to fix this promlem.
Old Nov 16, 2004 | 08:13 PM
chazekxt's Avatar
some people use the 400 ex boot but u have to cut about a inch off it....
Old Nov 16, 2004 | 08:32 PM
Don't 400ex intake boot bolt to the motor? both of mine clamp to cylinder and the carb.
Old Nov 16, 2004 | 09:22 PM
chazekxt's Avatar
not sure on that one but thats what they are using on others sites.
Old Nov 16, 2004 | 10:34 PM
radfastdude7777777's Avatar
Hmmmm, UPP makes boots for raptors to solve that problem, and might make them for the z. They are plastic boots, and much better quality.
Old Nov 16, 2004 | 10:39 PM
MURDR's Avatar
i took the stock boot and a dremel tool and shaved off a bunch of rubber on the inside of the boot to make it fit.
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Sassinm1
Sep 30, 2015 04:23 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MPDano
1) Engine problems..
Sep 20, 2015 09:48 PM
Ridgebackguy86
Sep 19, 2015 12:48 PM
