How do I get the hub off?
I"m trying to pull the right front hub off of an ltz250. The black hub is attached to the disk-break...I wasnt expecting it to be attached so I need to pull off the break caliper I guess? I'm not really sure how that comes off and I dont want to end up taking stuff off I dont know how to put back together. Anyway to take the hub-stud out without taking the hub itself off? I wouldnt hammer it but I dont want to bend/break the hub, the stud seems to be in there really tight.
you can pound it out with a hammer but be careful not to bend the hub
the studs are pressed in, just make sure you have the end of the hub supported
under the stud your removing or installing
