not running right/stalls
Old Nov 23, 2004 | 11:40 PM
intel's Avatar
Default not running right/stalls
this is a Ltf250f 4x4. 4 stroke this thing has been sitting for a year ran fine then. i drained the tank tore the carb down and cleaned it still wont run right.this has no choke it has the inrichener if i turn it on fires brifely then stalls(will not run with it on) trun it off fires brifely then stalls. it will run if i take the air cleaner out and cover the air inlet with my hand (baiscly chokeing it ) but if i remove my hand all the way it will stall within a few sec. if i warm it up useing the hand chokeing way it will idle but ruff there is a pop in the motor sometimes(witch it didnt do be for) i pulled the plug and cleaned it.it was black it has been run for may 45 min. pulled it again and now lite brownish white. im stumped here. could it be a bad plug ????????? thought i should add there is only 280mile on it.
thanks in advance
Old Nov 24, 2004 | 01:17 PM
intel's Avatar
tryed a new plug no change still all the same
Old Nov 25, 2004 | 12:55 AM
hondabuster's Avatar
If you use 1/4 throttle to start and run...will it run? Is the problem only at idle?
Hows the idle speed...could it be too low? wheres the mixture screw set at?
hugemoth
Jul 20, 2020 03:28 AM
Frisky2050
Apr 9, 2020 11:19 AM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
bzdok1234
30
Feb 23, 2016 01:55 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
