LTZ 400 Question
Old Nov 30, 2004 | 12:24 PM
immat's Avatar
Default LTZ 400 Question
I bought my LTZ Limited Edition in April and there is a squeak in the wheel everytime it turns. I took my bike to a safety class in June and there was a lady in the class that had an LTZ 400 that had the squeak too. Can anyone tell me what this is?
Old Nov 30, 2004 | 01:46 PM
ThaChad's Avatar
Is it comming from the Rear?
If it is, it is probably the Rear Rotor. Mine squeeks pretty bad. I guess that's a normal thing for thease Z400's.. From what i hear its because of the rotor being a solid rotor.. Alot of people who have switched to a vented rotor do not have the squeeking problem. My cousin has a 400ex that came with a vented rotor, and his doesn't squeek, but i don't know if that is because of the vented rotor or not.
-ThaChad
Old Nov 30, 2004 | 02:32 PM
chazekxt's Avatar
also the front shocks will squeak to. maybe shocks???
Old Nov 30, 2004 | 06:03 PM
dolfan87's Avatar
It's the rear brake. They all do it. My brother bought the DVX 400 at the same time I bought my Z, and they both squeak. My buddies all ride DS650's, and they all squeak.
The good news is it quits squeaking about midway through second gear, so I recommend going faster than that all the time. [img]i/expressions/face-icon-small-wink.gif[/img] J/K
Old Nov 30, 2004 | 08:16 PM
mucky's Avatar
its the rear brake rotor they always squeak. thats why I changed my rotor
and sometimes the bushings in the front shocks make noise too
Old Nov 30, 2004 | 09:29 PM
MURDR's Avatar
The front shock bushings do squek i took my bolt out and lubed the bushing up and the squek went away. You guys should try it. As for the rear rotor , i found were the rotor was hitting the brake pads and squeking . Then i hit that part with a hammer and evened the rotor out. No noise and i put new pads on.
Old Dec 1, 2004 | 12:35 AM
cgriffin's Avatar
Mine was squeaking last weekend. It was the little tin plate that bent in and touched the front rotor. It's quiet after bending it back out by hand.
CG
Old Dec 1, 2004 | 03:49 PM
ZillaRider87's Avatar
i have the same squeak in the back of my zilla, i think mine might actually be the bearings, but its most likley the rotor
Old Dec 5, 2004 | 09:23 PM
rockos's Avatar
my dvx 400 gots sum squeks sumtimes 2 its usually dirt on the rotar so i juust take ti down the streeet then ease on the breaks and it usually fixed for me
Old Jun 7, 2005 | 06:43 PM
ridefreak26's Avatar
YA I JUS BOUGHT A Z 400 AND IVE NOTICED MY REAR BRAKES SQUEAKING BUT I NOTICED THAT IT COULD BE MY AXLE DO TO IT LOOKS. BENT WHEN U R RIDING U LOO AT THE TIRES AND THERE MOVING
