stripping paint off frame
Old Dec 1, 2004 | 09:49 PM
ZillaRider87's Avatar
Default stripping pait off frame
How can i get the paint off my frame easily and fast. maybe some sort of liquid stripper? i dont have anyplace around here i could get it sandblasted, so any other suggestions would be helpful
Thanks
ZR87
Old Dec 1, 2004 | 09:51 PM
kdog's Avatar
Default stripping paint off frame
aircraft paint remover.dont get on your skin though.and its messy
k-dog
Old Dec 2, 2004 | 01:55 AM
pendejo's Avatar
I've used some industrial grade remover I got from my cousin(Auto painter), and it worked fairly well, but don't expect it all to just come right off!
Old Dec 2, 2004 | 09:33 AM
ZigZilla's Avatar
Could use a needle scaler if you have a compressor.
Old Dec 2, 2004 | 09:58 AM
Semms40oz's Avatar
I got good results using the spray on aircraft paint remover and a wire wheel. Had to apply the paint remover 4-5 times but it only took an hour. The first time you apply it most of the paint will bubble and lift, after that your left with though pathces here and there, but after a few more applications of the paint remover they either lift or are soft enough to come right off with a wire wheel.
hope this helps.
Old Dec 2, 2004 | 06:18 PM
rolsmojave3's Avatar
i used stuff from walmart...accidently got it on the car and boom...no paint there
Old Dec 2, 2004 | 07:24 PM
lol
i tried using some stuff i found in the basement called Zip-Strip, only 5 bucks , put it on, worked. so i bought another can and im waiting 20 minutes to go down and scrape it off.
Old Dec 2, 2004 | 07:56 PM
Vinson581's Avatar
here is what you WANT.
TAL STRIP at the auto parts store.
spray it on the frame, come back in 20min, hose it off, you are all done, belive me this is the only stuff that works.
v581
Old Dec 2, 2004 | 08:16 PM
v581
it only takes one coat and you can just hose it right off? how much is it
Old Dec 2, 2004 | 08:19 PM
caliraptor's Avatar
just take it to a body shop, they can strip the paint off easily. Sand blasting would be the easiest though.
