Z400 mods got a few Q's
Old Dec 7, 2004 | 04:01 AM
Z400xP650's Avatar
Default Z400 mods got a few Q's
Well im planning on putting a yoshimura full exhaust on my z400, and also adding a KN filter with a jet kit. For the setup i will be using is there a certain brand of jet kit i should use or that you have tried that works better then others???
also i notice a KN filter that is a stock replacement for 45 bucks and a pro flow KNsystem that uses a clamp on air filter
Am i better off getting a stock replacement and saving up anohter 60 bucks and getting 20 bucks and getting a KN air box lid??? just trying to see if its worth it to spend the extra money for a clamp setup. Also does the setup i chose seem like a good choice??
thanks ahead of time....
Old Dec 7, 2004 | 04:08 AM
pendejo's Avatar
Usually the pipe maker will send you their recommended jet's. I've ran direct clamp-on filters on my bikes and liked them alot, as long as your ide in dry conditions, otherwise drill holes in your stock lid(or remove it) and get a replacement K&N.
Old Dec 7, 2004 | 10:38 AM
MURDR's Avatar
Yeah, just get the K$n and take the lid of the air box. It works great, but if you want even more power with the addition of having the lid off the airbox drill some 1" holes all around the air box. You will feel a huge differance in throttle response and the engine will rev up quicker too. Especailly since you have the full yoshi. exhaust.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 7, 2004 | 11:02 AM
dolfan87's Avatar
I JUST added my full carbon Yosh pipe yesterday. I already had the K&N installed, so I simply removed the box lid. I replaced the main jet #130, with a #160, and the thing flat screams.
In my opinion it's a waste of money buying the whole jetting kit. I have piped two Suzuki's (my previous Z250, and now my 400) and just changing out the main jet was all they needed.
Good luck!
87
Old Dec 7, 2004 | 03:25 PM
YZLTZrider's Avatar
I recently did some mods on my Z. My opinion is DONT waste your money on the DynoJet Kit, Spend that money on the K&N w/ the billet clamp setup. All I really had to do is buy a mikuni #172. The only thing I used from the jet kit was the needle and I dont even think that was really needed.
Good Luck
Old Dec 7, 2004 | 10:17 PM
Z400xP650's Avatar
Well anyone know if the full yoshi pipes come wiht new jets???
Also is that a good pipe to get or should i be looking at others??
From everyones feedback im looking to Get the Full yoshi, Clamp KN kit, and KN box Lid since i ride in dusties and muddie areas most of the time.
Old Dec 8, 2004 | 01:29 AM
pendejo's Avatar
I personally have never used a Yoshi product, but considering they built Doug Gust's motor, and they know this motor inside and out, it only makes sense to buy that exhaust.
Old Dec 8, 2004 | 07:24 PM
FastZ's Avatar
some advice.....
a foam filter is way better than a k&n filter on every terrain except for sand. so with that in mind, if you ride only dirt and mud, then get a foam filter....if you ride in sand a lot, then get the k&n.
Old Dec 10, 2004 | 09:11 PM
witti's Avatar
Foam filters work better in dusty conditions. Noss machine/pro design filter set up has a better seal.
The Yoshi pipe should come with jets(ask when you order it).
I wouldnt get a dynojet kit. The dynojet kit didnt have the jet I needed. You can buy individual jets and needle for a lot less money.
Customer Service #1
May 15, 2020 08:46 AM
Sep 23, 2015 06:23 AM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
PrairieDog126
Sep 16, 2015 01:33 PM
1ArmBandit
Sep 8, 2015 08:59 PM
