next mod for z400
Old Dec 27, 2004 | 08:40 PM
mucky's Avatar
Default next mod for z400
ask murdr he had it done to his
Old Dec 27, 2004 | 08:55 PM
2112's Avatar
Dont waste your money on cams if you dont put a piston in. You will not see a differance. I would put a 13.5:1 piston and a set of hot cams, you will have to run race gas i use 110 oct. you will need a new cdi alba has one for $99.00. You could just put a new carb.
Old Dec 28, 2004 | 03:38 PM
alwaysAz400rider's Avatar
sounds like a pain in the a$$ to me. Why make it run on race fuel? That stuff is expensive. I just dont get why anyone wants more speed? Its not like you get the chance to go 80 mph anyway unless you are dragging? I guess if you have the money and the time it would be fine but jeez! I cant see spending so much money just to make it a little bit faster when the bike huals *** stock.
Old Dec 28, 2004 | 04:31 PM
witti's Avatar
Not true. I put cams in mine with the DRZ base gasket and there is a big gain in power. Same piston with slightly more compression, around 12:1 now. I can still run on premium. Without higher compressin I hear that you loose some low end, but there is still more power.
Old Dec 28, 2004 | 07:26 PM
  #15
2112's Avatar
If the bike is so great then leave it alone. You asked i"m telling and its not a little more power its a lot. I like my z but stock with just pipe jet and air its way to slow and way to soft. I would be happy to blow the fenders off your bike from start to finish.
Old Dec 29, 2004 | 07:22 PM
  #16
witti's Avatar
WTF?
I was leting him know that the piston wasnt needed to get a good power gain. But a piston would give more power.
NewGuy2481
Oct 6, 2015 05:54 AM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
1ArmBandit
Sep 8, 2015 08:59 PM
Jul 15, 2015 02:07 AM
yambam13
Jul 4, 2015 01:49 PM
