I need some jetting help on my Z 400 pleeeeeze
Old Jan 8, 2005 | 06:34 PM
ItalianStallion's Avatar
Default I need some jetting help on my Z 400 pleeeeeze
Just installed the Sparks pipe filter and jet...It called for a Dyno jet 150 but it bogged real bad at the top of each gear so I backed it down to a dj 146 but now it's to lean...should I put the 150 back in and move my needle instead?I'm on the 3rd clip
Old Jan 8, 2005 | 09:05 PM
7QuadSport7's Avatar
You have a z-400 to!!! man you really are the coolest person on earth![img]i/expressions/face-icon-small-wink.gif[/img]
Old Jan 8, 2005 | 09:10 PM
LOL.....Thanks.bro...I got the jetting though...I went to a 165 and put the needle on the 4th clip and turned the screws out 2.5 turns....runs perfect
Old Jan 8, 2005 | 09:15 PM
Great now you have another "work of art" LoL
o and my horses Andy and Jedi are much prettier than yours!!![img]i/expressions/face-icon-small-tongue.gif[/img]
Old Jan 8, 2005 | 10:06 PM
mucky's Avatar
I run a 170 jet and on the 3rd clip
so it sounds about right where you have it
Old Jan 8, 2005 | 11:48 PM
KCSOZ400's Avatar
Man I had the same problem with my 03 Z400. I took it to the local dealer and they could not get it right. Do yourself a favor and order a Dial-A-Jet from Thunder Products. The web site is WWW.Thunderproducts.com. I can't explain exactly how it works because it would take forever but I can tell you that it is very easy to install and works great. My quad has never ran so good. The technical help from Thunder products is top rate. The Dial-a-jet only cost me 70.00 and it was bargin. It was very refreshing to get something that actually works like it is supposed to. Hope this helps, Troy.
Old Jan 8, 2005 | 11:54 PM
Christoblue's Avatar
Stallion I have pretty much the same set up on my dvx 400 and I was running a mikuni 170. Just put in hotcams last week and I jumped to a mikuni 185
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
