Changing sprokets
Old Mar 2, 2005 | 12:18 AM
TxRedneck69's Avatar
Default Changing sprokets
i'm going from a 22" tire to a 25" tire, so will a change from a 41 tooth rear sproket to a 44 tooth sproket make a dfference? would this be an ok thing to do. I'm in the tire business, so i'm just thinking along the same lines as re-gearing for taller truck tires. Thanks for any info.
Old Mar 2, 2005 | 12:38 AM
maddog56's Avatar
That sounds about right. Typically 1" of tire diameter is the same as 1 tooth on the rear sprocket. So you should be back to about the same gearing by going up 3 teeth on the rear.
Old Mar 4, 2005 | 04:59 PM
designer626's Avatar
If you are going from a 22" tire to a 25" tire the percentage of change is 113%. If you multiply that by your 41 tooth rear sprocket you get 46.33.
For a tire size change with the least amount of performance difference from your current set up go with 46 tooth.
At least thats what the math says.
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Gwolf228
Feb 18, 2017 01:36 AM
Jackg17
Sep 26, 2015 09:30 PM
