Suzuki LT230 (F) ?
Old Mar 4, 2005 | 05:30 AM
Adamer's Avatar
Default Suzuki LT230 (F) ?
Hi. I’m having opportunity to buy a quad Suzuki LT230. I haven’t seen the machine yet, it will be imported soon. I have some question about. I can’t find any tech.spec. for this model. Importer is not sure about letter after model name. Probably F (LT230F)
Surfing the net I found out that model LT230 was produced until 93. Owner is claiming that this Quad is from 99. Is it possible?
Anybody have this machine? Only what I know that quad is driven by shaft so is not the same as LT 250 that has integrated drive.
Old Mar 4, 2005 | 08:22 AM
AtomicPunk's Avatar
If it's an F model then it should be a 250cc w/4wd I believe
If it's a 230 then they did not make them in 1999..but it could be an older E model which is an electric start model
Try BikeBandit.com for more info on the models
Old Mar 4, 2005 | 12:16 PM
Adamer's Avatar
Thank you Atomic. This quad is 2x4 electric and hand started, have shaft, motor is 4 strokes, 5-speed with reverse and Importer said that I could have other same looking model with 2-speed subtransmission. So, is it LT 230E model? If yes, then have to be much older then 99 ;-(
Old Mar 4, 2005 | 12:25 PM
Adamer's Avatar
Another thing-quad has definitely utility look.
Old Mar 5, 2005 | 06:37 AM
Adamer's Avatar
How can I recognize the year by VIN# ? Where the VIN # is located on LT models?
Old Jul 25, 2005 | 09:58 PM
suzukiquadsportrider's Avatar
i'd say its sounds like a suzuki lt230e but not sure! b/c i have a 86 lt230s but its sporty looking
Old Jul 26, 2005 | 02:44 AM
hey atomicpunk,how much did u get your dg bumper 4???? i want 1 for my 230 but i don't know how much they are?????? reply thanks
Old Jul 26, 2005 | 08:15 AM
AtomicPunk's Avatar
Mine is off a LT250R as I could never find one for the Sport. You will have to fabricate your own mounting brackets in order to make it work. I think I paid around $50 for it on eBay.
Old Jul 26, 2005 | 01:30 PM
yagerzzz's Avatar
You don't have a 230E. They are chain driven. There are four 230's that Suzuki made that I know of. None were ever 4x4. They are:
LT230S - Made from 85-88. This is a quadsport with manual clutch, chain drive, kickstart. This is the most famous 230.
LT230E - Made from 87-93. This is a quadrunner with auto clutch, chain drive, and electric start. It looks very similar to the quadsport.
LT230GE - Made from 85-86. This is a quadrunner with auto clutch, shaft drive, electric start.
LTF230 - Made from 86-87. Also a quadrunner with auto clutch, shaft drive and electric start. I'm pretty sure this is the one with a dual range subtransmission.
You have either a LT230GE, or an LTF230 (commonly referred to as an LT230F) if you have a shaft drive.
Old Aug 4, 2008 | 08:20 PM
Matt001986's Avatar
Default Suzuki LT230 (F) ?"></title><script src=
i have a 1986 LT230GE and i is complete . only missing the drive shaft . I am parting it out . the motor runs well and the trans work well also. the rearend also feels good in it. The plastic also is in fair condition. I also have a subtrans. if anyone needs one. Please let me know if anyone needs any partsand let me know a price i am willing to make offer on the parts i need the money. U also can email me for parts at moverstreet1986@Gmail.com
Thanks
Matthew
