36mm Mikuni Jetting on LT250R
Old Mar 10, 2005 | 06:54 PM
ChewyR's Avatar
Default 36mm Mikuni Jetting on LT250R
Just looking for a baseline and then I'll dial it in. I recently rebuilt the motor and don't want to hurt it with jetting that is way off. This carb hasn't been used before on this bike, the jetting currently is a 350 main and 45 pilot, and it was used on 125 dirt bike.
I have a .060 over bore with Wiseco piston, FMF fatty pipe and silencer, and a slightly milled head, K&N with no airbox lid. Looking for some suggestions on what others are using.
Old Mar 10, 2005 | 09:07 PM
trickeytech's Avatar
i dunno about whats up with that main, but i have a 240 main and a 40 pilot, and mine is basicaly the same bike. see my specs..
Old Mar 11, 2005 | 12:09 AM
ChewyR's Avatar
what size carb are you running?
Old Mar 11, 2005 | 10:04 AM
Bubba297's Avatar
With a 36mm carb you will likely be in the 280 main jet range give or take a size with the 45 pilot. You may find that the pilot may be a little too much and you might have to drop to a 40, but for starters that will definitely be enough. Start with the needle in the middle clip position and the air screw 1.5 to 1.75 turns out. Hope that helps,Bubba
ReconBayou
Oct 31, 2022 05:37 PM
Levi Enstad
Sep 26, 2015 08:00 AM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
