Would I have to????????????????
Old Mar 15, 2005 | 12:53 AM
branman250cc's Avatar
Default Would I have to????????????????
On my ozark what would i have to do to put a taller spring in the back of the 4-wheeler?Would i have to buy any thing extra so it would work.Thanks for the info.
Old Mar 15, 2005 | 04:51 PM
Come on guys give me some info.Please!!!!!!!!!
Old Mar 15, 2005 | 05:01 PM
maddog56's Avatar
Taller spring? What do you want to do with the bike? You can stiffen up the rear spring with some adjustments. If you want more ground clearance you wiill hve to get it from bigger tires. If you want a stiffer suspension becuase its valved too light for your weight then you will probably need a new shock and not just a spring.
Old Mar 15, 2005 | 05:09 PM
On my ozark in the middle (under where you sit) if i go over a bunch of roots the will get caught under the 4 wheeler then i can't go anywhere
Old Mar 15, 2005 | 05:26 PM
maddog56's Avatar
You need more ground clearance, and the only way to get that is with taller tires.
Old Mar 15, 2005 | 05:41 PM
Are you sure because I have mud lites on the back of mine and they help in the mud but dosen't on the roots?
Old Mar 15, 2005 | 05:44 PM
maddog56's Avatar
You can only move the quad up so much, maybe an inch, with suspension spacers or taller springs. If the roots are getting hung up on the bottom of the quad then you need more ground clearance. Taller tires are pretty much the only way to get that on your bike.
Old Mar 15, 2005 | 05:45 PM
and they are bigger than the others
Old Mar 15, 2005 | 06:42 PM
Vinson581's Avatar
this person is a bit slow.....
bigger taller tires are the only way with a lift kit, but you are going to need more power to turn the tires.....'
v581
Old Mar 15, 2005 | 07:17 PM
branman240bcc's Avatar
I agree
