Jetting questions
I got a couple quick q's on jetting. First and foremost, do you need a whole kit to do this or can you just buy the indiviual jets only?? Also i saw the stock was 122, what are you guys running and what results are you getting from this?? My cities elevation is 800', would this affect anything??? Also, i have only seen Dynojet kits, are there other brands. Thanks again for any help
Many folks have simply replaced the main jet with anything from 126 to 135 for only a few $. some have also added a washer under the needle jet to raise/richen. To get a needle jet that's adjustable (slotted with e clip) I believe you have to buy a kit. I bought my jet kit from Rocky MTn ATV for around $45 as well as a K&N filter. The jet #s are different so you can't compare to the OEM #s. Another member of this board installed a clutch kit in his auto. Depends on what you want your quad to do.
MIKEYTRXSHEEBANGS
Dunes and Dune Machines
Aug 27, 2015 12:57 AM
