Z400: Too Lean?
Old Apr 18, 2005 | 01:33 PM
hondabuster's Avatar
Default Z400: Too Lean?
If you look here
carb picture
Its #16, on the bottom side of carb.
Old Apr 18, 2005 | 02:20 PM
ThaChad's Avatar
Originally posted by: hondabuster
If you look here
carb picture
What is the black **** attached to #52?
Thanks,
-ThaChad
Old Apr 18, 2005 | 05:00 PM
Idle speed adjuster.
Old Apr 19, 2005 | 01:08 PM
dbuz's Avatar
I have about the same set up as you. If I take my airbox lid off, it starts popping. I am going to have to experiment with my jets also. What size are you running now? One thing you could do is barely turn the choke on and see if it runs better. You need to get a service manual and do the jetting yourself, seeing as you might have to rejet many times before you get it right. It will save you lots of money in the long run to buy the manual and do it yourself.
Old Apr 19, 2005 | 07:43 PM
  #15
teamgreen02's Avatar
Warm your quad up, then take it for a WFO run. Hold the clutch in and shut it down. Stop, pull the plug and see what it looks like. That is the best way to jet.
Old Apr 20, 2005 | 12:03 AM
  #16
ThaChad's Avatar
Another problem i have all the time, is when i am doing a WOT 5th gear, and i pull the clutch in to come to a stop, the second i pull the clutch in, the engine dies. I have no idea why, it just dies.
-ThaChad
Old Apr 21, 2005 | 09:15 PM
  #17
maczzz's Avatar
I'm going through the same jetting stuff right now. I found a great tuning advice page at( www.hmfengineering.com) regardless of the pipe you run, they spell out the tuning procedure in the forums section applicable to all 4 strokes.
Dammar
Apr 20, 2016 06:03 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
bvolks
Sep 13, 2015 12:57 PM
Minimod
Sep 10, 2015 09:20 PM
