Z400 noise
My freind has a Z400 that started making a loud rattle noise that sounds like it is coming out of the engine/transmission. It only makes it in 3rd,4th & 5th. We tightened up the chain and checked the sprocket and everything seemed ok. Also checked for loose bolts. Any ideas? Thanks in advance for any help. GB
I did talk to a guy with a z400 last summer, he asked if my timing chain went, beacause his did and bent his valves he said. Might be worth the shop rate to have a mechanic check it out if you don't find loose bolts.
jrooker6
Apr 23, 2016 07:36 PM
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
