Help! 89 LT250R exhaust valve
Old Apr 16, 2005 | 05:11 PM
80vwpickup's Avatar
Default Help! 89 LT250R exhaust valve
Can somebody take off the window on the right side of the engine and take a close up picture? I'm trying to get this thing back together and I'm not quite sure how it goes. Also how do you set the cap on the left side of the engine, to set tension on the spring
Old Apr 16, 2005 | 06:33 PM
80vwpickup's Avatar
I searched and found out to turn it 1 turn, but I am not sure that the right side is together right, its hard to explain but there are two parts that sort of interlock, one shaped kind of like an L which is connected to the linkage down in the case, the other which seems to interlock with it which is connected to the valve itself. Right now I have the part connect directly to the valve behind the part that looks like an L, I'm not sure if it suppose to be behind it or be in between the L<. I'll get a pic....
Old Apr 16, 2005 | 06:41 PM
80vwpickup's Avatar
Picture of exhaust valve on Ronnies
I need to know where #13 & 14 go. behind part #16 or inside of the L< deal, thanks...
Old Apr 19, 2005 | 11:04 AM
revhardlt250r's Avatar
http://www.naturecoastmotorsports.co...ion_detail.asp
Bonzhonda300ex
Sep 17, 2015 10:44 AM
bvolks
Sep 13, 2015 12:57 PM
black798
Sep 9, 2015 07:42 AM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
