03 Z 400 oil leaking, all over the top of hte head and under the gas tank? where is it leaking?
Old Apr 17, 2005 | 11:47 PM
JOEYG's Avatar
Default 03 Z 400 oil leaking, all over the top of hte head and under the gas tank? where is it leaking?
Hi, I notice the oil was leaking on my head pipe, I looked and it is all over the place, but there is a lot up top and under my gas tank, where can it be coming from? valve cover? any ideas? thanks a lot
Old Apr 17, 2005 | 11:57 PM
stewbing's Avatar
check your hoses there is a vent tube on top check it hope this helps
Old Apr 18, 2005 | 03:31 PM
03hmfz's Avatar
Clean off your motor and start in up and watch to see where. It's leaking, you may have to replace a gasket or two.
Old Apr 18, 2005 | 07:26 PM
rolsmojave3's Avatar
yeah...i'd check the valve cover gasket...and the vent line
Old Apr 18, 2005 | 10:52 PM
JOEYG's Avatar
Well i figured it out, the rear vavle cover bolt and washer on the right side is gone, I am hopeing that it is not stripped out and it just was loose and fell out. Should I loctite it? is the torque spec in the service manual? if not what should I torque it to? anything I should know or do i just put eh new washer and bolt on? thanks
P.S I hosed it off so I probably got water inthere, should I run it and then change the oil or just change it? thanks
P.S.S if the bolt hole is stripped ( I ordered a new bolt) what can I do then?
Old Apr 19, 2005 | 11:11 PM
JOEYG's Avatar
Thanks, I pulled it apart and sure enough it was stripped, I friend of mine (the guy that put it on last time is going to put a heli coil in it for. Do you have to reset your cam timing after this? I did not have the motor at top dead center and it made the cam skip a toothe when I took the cam journal off. any tips Thanks a lot.
Cummins Driver
Sep 11, 2019 01:22 PM
SDR-II
Sep 29, 2015 01:06 AM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
traumajunkie
Jul 5, 2015 03:03 PM
