Mud lites on the Eiger
Old Apr 24, 2005 | 07:59 PM
rolsmojave3's Avatar
Default Mud lites on the Eiger
I just put some new 25in mudlite XT's on my Eiger and i must say they are great...i went mudding on stock tires just a day before and can say the XT's will pull through anything compared to stock..they are still very light weight...the only complaint i have is that they don't slide due to the grip...lol...also...every now and then while turning..some where in the front end is making a clicking sound...it'll only do it once or twice in a turn...would this be a bearing or a CV joint..
Thanks
Old Apr 25, 2005 | 10:48 PM
bump...any of you guys have ideas on the problem?
Thanks again
Old Apr 26, 2005 | 02:24 AM
MeYHymN's Avatar
A bad cv joint will give popping whenever going in a left or right turn. I've never heard one just pop once or twice in a turn, but it could be a single spot going bad. Check your boots. Usually the boots go bad first allowing dirt to get into the joint. Jack the front end of the bike up and check for any play in the wheels, joints, steering, driveshaft, etc. Obviously don't do this on car ramps, put a jack stand under the center front. Examine the boots thoroughly. If all this fails jack the bike up completely on jack stands and fire it up and see if you can get sound to replicate in the garage. If you take the last route please be extremely careful. It's easier to track down the sound from a different point of view. Is the sound from the left, right or middle?
Old Apr 26, 2005 | 07:03 PM
it's coming from the left front tire area...it could possibly be a bearing...i was having a little too much fun going up on two wheels and driving...[img]i/expressions/face-icon-small-shocked.gif[/img]
Old Apr 27, 2005 | 03:13 AM
quadduck's Avatar
Been there done this. it was my wheel bearings. I have 589s and wow what a diffference. No more powerslides with ease and the fronts get so much traction that it can make it handle funny.
Old Apr 27, 2005 | 09:21 AM
ok thanks alot....are these easy to replace....I pretty much have all the tools needed...i've just never worked on a 4x4...anything speacial i should know about..thanks alot guys
Old Apr 28, 2005 | 01:09 AM
quadduck's Avatar
Depends on what you think is easy, you have to pop the ball joints out and the tie rod end off. Other than that its pretty standard.
Old Apr 28, 2005 | 04:04 PM
alrighty..thanks
Old May 4, 2005 | 11:09 PM
ok...i ordered the bearings...if they don't work and it's a CV...how hard is that to replace....or is it fairly striaght forward...thanks guys
Old May 6, 2005 | 01:21 AM
quadduck's Avatar
The hardest part about replacing a 1/2 shaft is the money that you spend. All you need is to go through the same process as replacing your wheel bearings and when you get to the part of pulling the shaft ijust needs to be popped out with a good tug. It has a splined shaft with a clip on the end.
