Q-racer a arm bushings
Anyone have any advice for putting replacement bearings in?
It took me about 3 hours just to get top and bottom arms off just because the old bearings were so shot, they were hanging on the bolts.
Now that there off, I can see that the old bearing races are FIRMLY stuck in there, years of dirts etc.
Drill them out? Hone? or shop for a -arms?
are they bare? with ball joints? bushings?color powdercoat?
email me, Id probably take them off your hands.
cmclean@schwendener.com
email sent.
FYI... Unless you have a press, it is very difficult to remove the old races. I have been there many times. It is not fun. Even if you have a press, it will take lots of wd-40 and torch to get them out.
yeah i had a torch on it, still no luck,
In any case, For some reason, I couldnt respond to your email.
try resending to cmclean17@aol.com
thanks
thanks
Qracer, let me save you alot of hassle first take the right size deep well socket and make sure its just a little bit smaller and drive it through. They can really be stubborn but they will come out then go to richardsbushings.com for 70 bucks you can get everything you need, Most bearing kits are 50 bucks per arm. Just my two cents hope it helps...
