King quad, worst handling quad ever?
maybe its me, this thing when on the brakes hard or soft and in a turn, it wants to flip. I also tried adjusting the toe in, front springs , the only thing that helps the twicy ness is keeping it in 4wd or diff lock. help
Mike545,
How are you driving the quad into the corner??? I certainly don't have the problem you're discribing. Are you using throttle threw the apex of the turn??? How much body english are you using??? I found I had to adjust my riding style and use more body english and a lot more throttle... I am running stock spring with 4 clicks of preload and 1/16 toe out... (Plus a winch up front.) Look forward to hearing more, Hibrass |
Mike 545, is this the first big bore ute you've ridden ? On the trails the k/q out handles any of the other irs utes I've ridden by far.
Well it doesn't handle like a YFZ 450. but no doubt it's the best handling 4x4 out there with all due respect to the Rincon. Handling was one of the main reasons I bought a KQ. Maybe something is tweaked on yours?
mike; the kq is hands down the best trail mannered ute going. i do agree with you that the kq wants to roll and nose dive , especially in hard cornering. if you plow snow the front end will sag 4" when lifting plow. high lifter front springs will solve these problems. for $80 and an hours work its the best money i ever spent. just be careful or have it done cause those springs can be dangerous to change. when i bought mine last fall they were listed for the brute force and said also fits kq but that may have changed by now. anyway both take same hl springs. give em a try and im sure youll love them. good luck and safe riding.
Take a look at my other machines.....I can tell you I drive my KQ like my sport machines...best machine out there.
I came from a raptor and I find nothing wrong with the handling other then it can throw you around in the ruts a little, but you can muscle throw that!
Originally posted by: KingQuader Well it doesn't handle like a YFZ 450. but no doubt it's the best handling 4x4 out there with all due respect to the Rincon. Handling was one of the main reasons I bought a KQ. Maybe something is tweaked on yours? |
I would agree that it nose dives into corners. More preload up front helped this, with mine. Interested in the High lifter springs... but probably will not spend the money- right now!!!
Marshall |
toe out was alot, need specs, adj by eye, did help, have springs set on four, if riding and hit an rock or someting, pretty big, on other quad you go over, mine wants to go to full lock on that side. riding 10mph and up, hit the brakes ,(front) and turn, and it want to rool you . i went over at 3mph, down a trail. is 1st 600 lb quad. have the 450r and i know there diff, but i know how to ride , and im saying its twitchy, in dirt wheels(i think) king quad vrs. prarie, two experienced riders feel the same, and gave the knod to the priarie, in 4wd it is alot less twitchy, i heard the tie rods are junk and flex under heavy steering, i do ride very aggesivly. ideas
