anything new on the z 400>?
Old Jul 6, 2005 | 06:47 PM
suzukiltz's Avatar
Default anything new on the z 400>?
Its been awhile since iv looked at atvs im more into cars now. But if anyone has any info on the Z 400 id like to hear some. Last time i checked was 10 months ago and the rumers just started with the Z 450 i wanna get a new Z 400 and want to know the new parts that are on it that are different from the older one thanks guys
1986 Kawasaki Bayou 300CC
Bigger Carb, NGK race plugs
C.A.I new tires with more traction
Performance oil , race Gas with octane boost
8HP gokart killer
Old Jul 6, 2005 | 06:55 PM
RedGoblin's Avatar
I know the shocks are better overall and have rezzies now. There have been several measures taken to lighten the machine up in a few different areas and I believe the engine was slightly beefed up as well. There may be other things but I think those were the main ones.
Old Jul 6, 2005 | 06:59 PM
blackbird's Avatar
the 2005 have better shocks ,a bigger cam and bigger carb than the 03-04
Old Jul 6, 2005 | 07:03 PM
SuzukiDoug's Avatar
Blackbird does the 03 have the weakest frame? If I wanted some cheap stock upgrades could I use the stuff off of a 05?
Old Jul 6, 2005 | 07:11 PM
blackbird's Avatar
their are some that had weak frame and some that didn't.if you race gusset the frame or if your jumping 60-80ft jumps to.every frame will crack if rode hard enough.if you can find the 05 shocks cheap or 450r shocks cheap go for it.but your best bet is elka or works shocks.get them set up for your weight and you'll wonder why you didn't do a shock change sooner.aftermarket shocks on the z makes a big differance
Old Jul 6, 2005 | 07:16 PM
SuzukiDoug's Avatar
Cool thanks man. Also what about the 05 carb? Would it be pointless to put it on my 03? I am just looking for cheap stuff right now because the wife is limiting me!! LOL I have to wait for winter since we are spending every last penny on the house and what not...
Old Jul 6, 2005 | 07:22 PM
suzukiltz's Avatar
Thought it was only the shocks,carb and alittle bit of motor work huh i guess not much has changed thats good.
1986 Kawasakin Bayou 300CC
NGK race plugs, C.A.I
Performance oil, Race Gas with octane boost
New tires with more traction.
Old Jul 6, 2005 | 07:26 PM
suzukiltz's Avatar
the 03 had bad welds. If i had one i would have just welded it my self I would do a better weld then the computer.
I made my own Grill for my ATV.
bigger Carb, NGK race plugs(hotterplug)
New tires more traction C.A.I
DIFF lock even more traction
Old Jul 6, 2005 | 07:32 PM
blackbird's Avatar
the 05 carb is a 37mm and the 03-04 carb is a 36mm not going to get much if a change at all.i would get a 39fcr or a brock carb ,if you plan on getting a different carb
Old Jul 8, 2005 | 12:34 AM
SuzukiDoug's Avatar
Also I have the chance to pick up a 05 cylinder and piston that are hardly used for 150 shipped is that a pretty good deal? Should I even worry about it? Thanks!
