Z400 Brake question: PLEASE HELP I WANT TO GO RIDING!!
Old Jul 9, 2005 | 05:53 PM
Exrider22's Avatar
Default Z400 Brake question: PLEASE HELP I WANT TO GO RIDING!!
I have a kfx400 and i have to pull the brake handle pretty far before it even engages the brakes, to put it short they have a spongy feel. I searched the forums and everyone reccomended bleeding the brakes which i just did. Needless to say i still have to really sqeeze before i see any results. Please help because i want to go riding tomorrow!
Old Jul 9, 2005 | 06:08 PM
QuIcKrIdEr's Avatar
after yu bled the brakes did yu fill the brake fluid back up, and pump it into the system?
Old Jul 9, 2005 | 06:21 PM
Exrider22's Avatar
i filled it back up, by pump it in do you mean squeeze the brake lever, cause i did that too
Old Jul 9, 2005 | 07:55 PM
flynhi250r's Avatar
Sounds like you didn't do a very good job of bleeding them. Use you Clymer book and follow the directions exactly to get them bled correctly. Other than the master cyinder being bad or the seals shot on the caliper, which I doubt on a quad this new, it will be they just need bled properly and have the correct amount of fluid.
Old Jul 9, 2005 | 08:05 PM
RacinJason's Avatar
As easy as bleeding brake lines and mast cyl is in theory I have had lines that wouldn't bleed up until I used a vacuum bleeder.
Make sure you only use the correct brake fluid...its stamped on top
DO NOT use dot5
if a basic bleed doesn't get it done throw it in the back of the truck grab a sixer and go over to the discount brake/alignment place and trade for a good suck
braaaaaap
who uses thier brakes anyways
Old Jul 9, 2005 | 11:10 PM
Exrider22's Avatar
actually my neighbor mentioned that we could use his vacuum bleeder tomorrow, if you think it will help then ill give it a try. Thanks for the helps guys, and yeah the brakes are pretty useless........[img]i/expressions/face-icon-small-shocked.gif[/img]
Old Jul 10, 2005 | 12:31 AM
fullthrottlez400's Avatar
make sure while you are bleeding the brakes that you always have a high amount of brake fluid in the master cylinder that way when it gets low you don't suck more air in between the brake fluid. Always keep the brake fluid at least half full while bleeding.
Old Jul 10, 2005 | 09:42 PM
Exrider22's Avatar
yeah i bled them like 4-5 times {and kept the fluid at lest half full} and there starting to feel a little better, not as good as before though, it seems like theres still a decent amount of play. Think i should keep bleeding them? We checked the calipers and pads and everything seems to be working good. any input is greaty appreciated, thanks again guys for your help.
Old Jul 11, 2005 | 12:20 AM
make sure your lines dont have any pinholes or anything in your lines and make sure your lines are connected good with the caliper and that you arent sucking air back in the line....otherwise I cant tell you what else would be wrong
Old Jul 11, 2005 | 12:35 AM
Exrider22's Avatar
okay ill double check them, they are starting to stiffen up though...
