Quadmaster fuel problem
Old Aug 21, 2005 | 05:32 PM
farmerdad's Avatar
Default Quadmaster fuel problem
I have a 2000 quadmaster 500 with 650 miles on it and it has developed a problem where it acts like its run out of gas. The only way to get it running is to switch to prime on the fuel switch. I have taken it to the dealer twice for repairs and the dealer can not find any problems. Have any of you had any similar problem and can suggest a fix?
Thanks
Old Sep 4, 2005 | 11:50 PM
truckie's Avatar
I have the same problem did you ever find the problem?
Old Sep 5, 2005 | 12:14 PM
adherna's Avatar
Try taking the filter to carb tube off and then tell me what it does.
Old Sep 6, 2005 | 01:26 AM
MeYHymN's Avatar
Sounds like either the vacuum tubing or the vacuum diaphram in the petcock is going bad. Change the vacuum lines with some good fresh hose. Take the petcock completely apart and make sure it's clean. While you're at it, replace the fuel line and purchase a clear in-line filter. Then if that doesn't work hook a vacuum pump up to the vacuum line on the petcock, apply vacuum, and see if fuel flows. If you don't have a vacuum pump, you could try sucking on the hose, but whether you can generate enough vacuum or stand the ridicule from your friends remains to be seen.
If you get fuel flow w/ fresh hose and the pump, but not w/ the carb, then you've got some deeper issue (ie. bad rings, problems in the valves, etc. etc.)
Good luck.
Old Sep 6, 2005 | 01:51 PM
hondabuster's Avatar
Check the vacumn hose that goes to the fuel selector. It may have a leak. If that doesnt do it, just leave it in prime the whole time youre running, the needle valve will shut the fuel flow when the float bowl is full. And when youre done riding, turn it back to on.
Old Sep 7, 2005 | 10:20 PM
farmerdad's Avatar
not yet but am trying some vacuum checks suggested by a couple of others---I will let you know the results
Thanks
Old Sep 7, 2005 | 10:30 PM
farmerdad's Avatar
Thanks I wll check the vacuum out and the diaphram also-----did find some dirt in the petcock
micheleLeigh
Jul 12, 2015 02:50 AM
Unzzy66
Jul 11, 2015 10:01 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
Mikea1978
Jul 4, 2015 12:37 PM
