need help on the kfx 400
Old Aug 25, 2005 | 02:10 PM
yamahawarriormods's Avatar
Default need help on the kfx 400
Old Aug 25, 2005 | 02:14 PM
oops so i have a hmf slip on and i have been trying to get the jetting but i cant seam to get i perfect it just seem like i dont have power going up steap hills .... i went by what dyno jet recommends and it seemed rich i started with a 150 and now i am down to a 144 and still have not noticed any thing am i going to lean should i be going up i am just confused
Old Aug 25, 2005 | 08:09 PM
come on please somebody must have a idea now i went down to a 142 and that was definetly lean but the the 146 seamed gut less up hills
Old Aug 25, 2005 | 09:27 PM
LTZ's Avatar
LTZ
What else did you do? Airbox? Filter? Needle setting?
Old Aug 26, 2005 | 12:55 AM
yoshz's Avatar
Did you try running it without re-jetting? If all you did was put on a slip-on and nothing else, you may not need to rejet. If you put a higher flow filter and/or remove the airbox lid or snorkel then you will definately need to rejet. More air + more gas = more power. I'm guessing that with only a slip-on you may not notice a big difference in power. If it doesn't run well in the lower rpms under load but runs good at higher revs under load then I think you might be rich, but if as you say it doesn't do well on the hills then I think you are lean.
Old Aug 26, 2005 | 12:43 PM
i am running a open air box i went i am on the 4th clip on the needle the low end power feels good even the mid range but when i am under heavy load and floored it seemes gut less
Old Aug 26, 2005 | 02:27 PM
kawiking's Avatar
take your air box lid off.if it runs better than you have it rich. i had a k@n ,no air box and i cut the baffle out and i was running 160 main . it didn't feel to bad but i knew it was kind of rich.i have a new cdi and a full comp yoshi now and i'm running a 165 main and half a turn on the air mixer screw and it's running damn good. i think it's right on know.
Old Aug 26, 2005 | 08:29 PM
witti's Avatar
Try running it with the airbox lid on.
I would try a bigger main jet. Somewhere around a 155-160 with an open airbox.
With the stock pipe I removed the airbox lid and installed a 150 mikuni mainjet and it ran great. With the ful pipe I ran a 160.
