Eiger shocks question
Old Sep 12, 2005 | 12:34 AM
TSA's Avatar
TSA
Default Eiger shocks question
I hung a snow plow on my 02 Eiger, and found the plow to alomst be too heavy for stock shocks. Anyone have this problem, and what shocks did you replace with. Dealer said stock shock specs were not avail (?) so he couldnt reccomend aftermarket shocks w/ out knowing stock spring tension. Any thoughts?
Old Sep 13, 2005 | 12:31 AM
GSPKurt's Avatar
It's not the shocks, the stock springs are too weak. Get stiffer springs. That'll take care of it.
Old Sep 13, 2005 | 10:02 AM
TSA's Avatar
TSA
Any idea if the stock shock springs can be removed easily? And, any spring suggestions? Dealer said no way to tell stiffness of stock springs, thus it would be hard to determine what new springs to buy? Thx
Old Sep 14, 2005 | 10:31 AM
sliver's Avatar
I'm going to try to make 1" spacers to shim some compression into the springs(if I ever get time!). This should work, I have a 60" plow and weigh 240 lbs so I need to try something. I'll post back on how it works hopefully soon.
Old Sep 16, 2005 | 12:21 AM
PD's Avatar
PD
I added a Warn country 52" plow and a Warn 3.0 winch. Mine sat perfect and has worked perfect.
cornermike
Sep 10, 2015 08:30 AM
John Reed
Sep 9, 2015 03:46 AM
Rooky
Sep 9, 2015 03:16 AM
bmark0610
Sep 7, 2015 09:42 PM
MooseHenden
Sep 6, 2015 04:24 PM
