2005 Z400
crashed my Z400 had to buy A new frame. Still ran but frame was history. Put it all back together now the only way I can start it is by spraying some starting fluid in the air cleaner. But that makes it run so hot the pipe turns red hot. any insight on what to do?[img]i/expressions/face-icon-small-disgusted.gif[/img]
If you have 05 or 06 it's probably got the titanium head pipe like the yfz. These are a lot thinner than steel but just as strong. The titanium ones will get red and is normal. BUT I'M NOT TELLING YOU IT'S DEFINETELY NORMAL IN YOUR CASE. Does it run on gas ? Or does it only run while your squirtin ?
It only start's with starting fluid. with gas it will turn over and backfire once in awhile. I think muskey may be right about the vac. leak. have to check it out this weekend. THANK'S GUY'S
Vac leak causes a lean condition. That backfiring is a sign of being lean. Not saying that a backfire means that it is lean, just that it's one of the symptoms. Could timing chain have skipped? Just another possibility. What color is spark plug? Have you tried running it choked? If it's lean, it will run better choked. Make sure your actually getting fuel to carb, then try the choke thing. If you can get it running on choke you can use that starting fluid to find vac leak. BE VERY CAREFUL--FLAMMABLE Spray around suspect area, if it revs up you found your leak.
