How to make LTZ250 Sport Quad get More Power?
Old Jan 3, 2006 | 06:53 PM
  #21
suzukirider55832's Avatar
Default How to make LTZ250 Sport Quad get More Power?
Originally posted by: Pinkkid
I have a feeling it is for an older suzuki 250, the add did not say LTZ250 it just said LT 250, but itwas for a quad. I think I may go ahead and keep my LTZ250, it is ggod to have it for kids, friends whoever to ride and then at a later date I will buy the LTZ400.
wait...if it said lt 250 its gotta be the lt250R...it's definately not for the ltz250
Old Jan 3, 2006 | 06:54 PM
  #22
but then again...why would he make a kit for a two stroke if the company is four stroke tech?...interesting...please give me the number!!!
Old Mar 4, 2007 | 08:57 PM
  #23
kirkwoodroughryder's Avatar
how did u get that clutch on ur 250 I need 1 4 my 05 250
Old Jan 26, 2008 | 07:06 PM
  #24
A2mazou's Avatar
Hi also looking to get a little extra power can you direct me in the right way please . one more question what grade of oil and how much for rear diff
Old Jan 26, 2008 | 10:32 PM
  #25
JustRandy's Avatar
Old thread eh? The 273 kit is for a 1989 or 1990 LT250s quadsport.
More power? New exhaust, bigger carb, KN air filter are some simple things. High comp piston, bigger valves and porting job, and cam would be the more complicated things.
Old Feb 10, 2008 | 01:31 PM
  #26
foXracing150's Avatar
my first mod was a hotcams stage 2 kit for my z250, it helps a lot in the higher rpm's so u can pull up a hill much better. plus its cheap... only about $170
Old Jan 26, 2011 | 04:33 PM
  #27
zak_'s Avatar
Default no
Originally Posted by Pinkkid
Oh, the YFZ450 blows the LTZ250 away!!!!! :-)
your a fast one arnt you
Old Jan 26, 2011 | 04:34 PM
  #28
zak_'s Avatar
Default ltz 250
i just blew my top end out of my 2008 ltz 250 and i need a bore kit where can i get one and how much
Old Apr 28, 2013 | 02:17 PM
  #29
robdawg98's Avatar
When I got my 2004 ltz250 all it had was a jardine exaust but it got boring quick. Then over the winter I put in a dynojet jet kit which made a big difference. Then I put in a K&N air filter which made a litter bit of a difference from the old air filter. After that I put in an aftermarket ignition coil which made a big difference and gave it alot more power for little money. Before I made these mods I had a hard time making it up the big hills at the trails and now I have no problem going up those hills in 2nd gear.
Old Apr 28, 2013 | 02:23 PM
  #30
robdawg98's Avatar
With a jardine exaust, dynojet jet kit, K&N air filter and an aftermarket ignition coil my ltz250 has no problem keeping up with a honda 300ex and can keep up with the 400s
