How to Change Coolant
Old Sep 29, 2005 | 12:34 AM
devildog1's Avatar
Default How to Change Coolant
I'm going to swith the coolant out to engine ice. How do you do it? Manual doesn't say. I can see where I disconnect the tube from resevoir, but how do I get it out of the radiator. Where do I refill? The reservoir or radiator?
Thanks
Todd
Old Sep 30, 2005 | 03:54 PM
yoshz's Avatar
Hard to help without knowing which quad you have. Also, make sure the coolant you use is compatible with your quad. I know my Z400 has an aluminum radiator and requires a coolant designed for aluminum. On mine there is a small bolt low on the right side of the engine. First get something under it to drain into, then remove the bolt, then remove the radiator cap. As soon as you remove the radiator cap be ready, the coolant will shoot out the side past your container.
Old Sep 30, 2005 | 04:08 PM
devildog1's Avatar
Sorry, King quad
1ArmBandit
55
Oct 14, 2015 09:03 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
essonlaker
Sep 10, 2015 01:12 PM
Randy Lee Frye Sr.
Sep 9, 2015 02:30 PM
Kenidah
Sep 7, 2015 07:50 PM
