Air Pressure
Old Oct 25, 2000 | 09:54 PM
pusher's Avatar
What do you run for tire pressure? For example if the book says between three and five pounds,witch one do you run at or do you go a little more or less. Do you run the front the same as the back ? I know all tires are different and so is where you ride. But how do you like your tires inflated and why ?
Old Oct 25, 2000 | 11:01 PM
mojave4's Avatar
I will run less air in my rear tires if it is wet and muddy where i am riding right around three pounds.I always keep my fronts at five.less in the rear gives me better tracktion in those conditions.
Old Oct 27, 2000 | 01:36 PM
getoutofmyway's Avatar
A quad will get stuck faster because of loss of ground clearance, it bottoms out and your stuck, no if, ands, or buts. You should always run higher air pressure when going mudding so that your ground clearance will be best. I run 5-6 lbs for mudding and about 3 for everything else.
bmxatv10
Oct 14, 2022 06:23 PM
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
2many2ride
Sep 27, 2015 04:35 AM
MPDano
1) Engine problems..
Sep 20, 2015 09:48 PM
Hw00d
Sep 10, 2015 08:53 AM
