z400 coolant change?
Old Oct 20, 2005 | 09:08 PM
garrett5462's Avatar
Default z400 coolant change?
how do you change the coolant on the z400?
Old Oct 21, 2005 | 05:18 PM
bump?
Old Oct 21, 2005 | 10:36 PM
yamahawarriormods's Avatar
there is a screw that you can pull out right on your water pump cover on the left side of the engine
Old Oct 21, 2005 | 11:26 PM
so if im jsut putting back in regular coolant/antifreeze 50:50, i wont need to worry about flushing the system or anything like that that people talk about when using engine ice.
Old Oct 22, 2005 | 10:53 AM
TheCommonMan's Avatar
Take off the radiator cap and the over flow res cover. The screw is on the right side of the engine in front on the rear brake lever. Put a pan under it. Pour some water through it after you drain it to get everything out.
Old Oct 22, 2005 | 04:32 PM
thanks
1ArmBandit
55
Oct 14, 2015 09:03 PM
NewGuy2481
Oct 6, 2015 05:54 AM
essonlaker
Sep 10, 2015 01:12 PM
Randy Lee Frye Sr.
Sep 9, 2015 02:30 PM
1ArmBandit
Sep 8, 2015 08:59 PM
