unknown suzuki
Old Nov 15, 2005 | 01:50 PM
firemansam's Avatar
Default unknown suzuki
Hi to all,
As a brand new member to this forum (and to quad bike ownership)I apologise in advance for any trivial info that I may request.
I am trying to identify a full size red Suzuki quad, it is an aircooled 4 stroke 250 cc, it has high and low ratio's, reverse gear and 4 wheel drive, semi automatic, hydraulic front drum brakes, and cable operated rear brake. It has front and rear carrying racks and tow ball fitted, it also has twin rectangular head lamps. I do not know the year of manufacture but I suspect late 1980's early 1990's.
I require a starter clutch and a head gasket set. It will be a UK spec machine as I live in Central Scotland
Mny thanks, Firemansam
Old Nov 15, 2005 | 03:43 PM
SuzukiZ250Kid's Avatar
I'm guessing that it is a Quadrunner 250. Not sure I can give you any more information than that.
Old Nov 15, 2005 | 04:24 PM
deanz400's Avatar
the motor should have cc of motor cast on the side in small letters my guess might be a king quad
Old Nov 15, 2005 | 05:57 PM
quadracer325's Avatar
I would guess a king quad, but am not sure they made those in red in the early 90's.
Take the motor vin number to a dealer and have them trace it.
Old Nov 15, 2005 | 07:06 PM
Scottishquads's Avatar
Welcome there Firemansam. You will find the serial number on the rear crossmember on the l/h side angeling to the front under the mudwing. There is a good chance that your bike is a Quadrunner LTF250F
Old Nov 15, 2005 | 11:38 PM
RealAce's Avatar
yeah that sounds like a quadrunner or quadsport for the time sounds right
Old Nov 16, 2005 | 12:48 PM
suzuki4ever's Avatar
it is probly a suzuki lt250f, they ar the only ones with 4 wheel drive and a 250 cc engine, the king quad has a three speed but tranny (high, low, and super low) and is a 280 cc motor. they only came in green and blue as well, i think. the lt250f quad runner came in red
Old Nov 16, 2005 | 01:19 PM
DavidLT250S's Avatar
does it look like this? http://home.ptd.net/~wcbarret/88Quad.jpg just copy and paste it to another page
Old Nov 16, 2005 | 05:50 PM
firemansam's Avatar
Yes, it has, it's a 248cc,
Thanks
Old Nov 16, 2005 | 05:53 PM
firemansam's Avatar
Thanks for the info, I'll check the number tomorrow, can you help in sourcing the parts as I'm in Glasgow most day's, if so can you leave a contact number,
Cheers
