New King Quad ..... 100Hour service Question
Old Nov 22, 2005 | 07:42 PM
56Nomad's Avatar
Default New King Quad ..... 100Hour service Question
I picked up a 2005 King Quad with only 16 hours on it. Manual says I need to inspect/adjust valves
at 100 hours which I want to do myself.
Are there any links on how to do this?
Thanks
Old Nov 22, 2005 | 09:51 PM
4FITTY's Avatar
This is a shim and bucket set up you might just want to take it to a shop because you have to remove the cams to change the shims
Old Nov 22, 2005 | 11:57 PM
56Nomad's Avatar
4FITTY
I found the information in the shop manual. It looks like I can check the clearances with out removing
the cam....... but if they are out of spec, I'll need to take it in to a shop.
It may not require removing or replacing shims if I'm lucky and they are within the tolerances.
IN: .10mm - .20mm
EX: .20mm - .30mm
Does that sound right?
Here is the shop manual page Click
Frisky2050
Apr 9, 2020 11:19 AM
toonces
Oct 16, 2019 12:11 PM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
yambam13
Jul 4, 2015 01:49 PM
D-Hagz
Jul 4, 2015 02:19 AM
