Fuel in Oil! petcock or bowl problem?
Old Dec 28, 2005 | 05:36 PM
vdubspeed's Avatar
Default Fuel in Oil! petcock or bowl problem?
97 Suzuki Quadrunner 250 2X4. 2K miles
Bought it three months ago. minor repairs got it running but still "rich"
did a 14 mile break ride and it checked out fine.
After the ride i noticed the petcock was in the "off" position the whole time.
Parked the ATV for 3-4 weeks.
Started it up great but then HEAVY white smoke.
I noticed the oil level was high.
Began to drain the oil and it looked more like water and smelled like fuel.
So...I know something is leaking and washing past the rings into the oil. My theory is that it's either a bowl problem and the float is not doing it's job or the petcock. Can a broken petcock flood a motor?
I need to fix this thing so I can sell it. It's the wife's and since she's pregnant she won't ride it anymore.
Thanks,
Jason.
quad1
quad2
quad3
quad4quad5
Old Dec 28, 2005 | 11:09 PM
IdahoVinnie's Avatar
You have 2 problems. Replace both the petcock AND the needle/seat (or at least check for debris that may be not allowing the needle to seat properly).
I assume that when you said "Began to drain the oil and it looked more like water and smelled like fuel", that you meant that the oil viscosity was very thin. If there were water in it, the oil would look like a chockolate milkshake.
By itself, a bad petcock won't flood an engine, but if the needle/seat also allow fuel to seep into an engine, then the excess fuel will ultimately end up in your oil. A bad needle/seat can also contribute to a rich running condition.
skinnyr6
Aug 25, 2023 02:18 AM
micheleLeigh
Jul 12, 2015 02:50 AM
Unzzy66
Jul 11, 2015 10:01 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Mikea1978
Jul 4, 2015 12:37 PM
