Z-400 QUESTION NEED HELP??????????
Old Dec 30, 2005 | 08:54 PM
omar's Avatar
Default QUESTION NEED HELP??????????
WHAT IF I DONT CHANGE THE MAIN JET WHEN I GO FROM A 3000 AND LOWER ALTITUDE TO ABOUT A 4500 ALTITUDE? I HAVE A DYNO JET KIT AND IM PUTTING THE MAIN NEEDLE JET FROM 3000FT AND LOWER. WILL THERE BE COSTLY CONSEQUENCES PLEASE HELP. THANKS
Old Dec 31, 2005 | 03:32 AM
Daniel631's Avatar
Default Z-400 QUESTION NEED HELP??????????
You will run a little rich. It won't kill your motor or anything. Worst case scenerio it will bog. The air is thinner the higher you go.
Old Dec 31, 2005 | 03:41 AM
rescuediver's Avatar
We run our z400 from sea level to about 5500' feet with no problems[img]i/expressions/face-icon-small-smile.gif[/img] If it does effect your motor, just be prepared for a little lag time in the response you get from the engine.
Old Dec 31, 2005 | 04:29 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
We ride everything from BELOW SEA LEVEL, to over 10,000'. Here is my solution to the problem of rejets for altitude changes:
http://forums.atvconnection.com/mess...word1=ALTITUDE
There is no harm in running rich, except that it reduces performance and may foul your spark plug.
Old Dec 31, 2005 | 05:41 AM
Daniel631's Avatar
Doesn't the Z-400 have a CV carb????? If it does you shouldn't have to touch the jets.
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
