eiger fuse problem
Old Jan 4, 2006 | 06:10 PM
eigerogre's Avatar
Default eiger fuse problem
My 05 eiger starts,runs till hot,then blows 10 amp IGN fuse and dies. I put 12 volts to the cooling fan and it comes on,so thats ok. Is it the fan switch or sensor next to it? How do I check? HELP.
Old Jan 5, 2006 | 03:35 PM
jcheil's Avatar
Maybe you have a wire that is loose and rubbing on something that gets hot (exhaust, etc). Then, when it is hot, the insulation on the wire melts a little, thus shorting it out to ground. When it cools, the insulation contracts back to eliminate the short. I had a similar problem with the main positive starting lead on my vinson where it rubbed on the frame and eventually wore through the insulation. A zip tie or two fixed it.
Old Jan 5, 2006 | 05:50 PM
Prospecter's Avatar
I had the same problem with the 10 amp IGN fuse blowing on my 05 Eiger. I traced it back to the sensor for the foot brake. When I disconnected the brake sensor, the fuse hasn't blown since.
__________________________________
2004.5 Polaris 500HO
2005 Suzuki Eiger
2005 Kazuma Dingo 150
Old Jan 8, 2006 | 05:42 AM
eigerogre's Avatar
Problem found with 12v tester.I hooked the lead to the load side of the IGN fuse block and started wiggling wires. problem showed up in the heat light indicator bulb.The metal terminals inside were touching ,At the same time ,the fan switchisnt working so .....engine overheats....heat indicator light comes on......blows fuse Riding in Pa this Sat. Thanks
JoAnnS
Jul 23, 2015 02:18 PM
hondarider1234
Jul 21, 2015 11:53 PM
Unzzy66
Jul 11, 2015 10:01 PM
