Electrical Problem
Old Jan 5, 2006 | 11:00 PM
dearthslayer's Avatar
Default Electrical Problem
My '04 z400 has power everywhere, (lights, Neutral light, etc..) but it has no power to the engine. Acts like the switch is off. Replaced CDI box, but no change. Could someone give suggestion
Old Jan 5, 2006 | 11:26 PM
Daniel631's Avatar
Are you saying it won't turn over??? Or it will turn over and just won't start???
Old Jan 5, 2006 | 11:30 PM
I push the starter button and its like there is no power. nothing happens but everything else works. when I tried to jump it off it acted like switch was off. took switch apart seems to have good contacts. Checked fuse, it's good.
Old Jan 6, 2006 | 12:41 AM
Daniel631's Avatar
Is the engine stop switch in the on or run position???
Old Jan 6, 2006 | 07:50 PM
03Z400Rider's Avatar
Check the starter relay. its located beside the battery. try jumping the two wires together. the motor should turn over.
Old Jan 7, 2006 | 06:31 AM
Update:
Engine will not turn over at all with the starter button. key switch is on and the run switch is on.
Tried to roll and jump it off motor turns no fire.
First guess was that CDI box was bad. Installed SRP CDI rev box. (ooooh way wrong $179.00 guess)
Tried to hot start starter from battery straight to starter. starter turns over, still no start.
Jumped accros the starter relay, motor turns no fire. (thanks 03Z400 rider<u>Text</u>
Checked Clutch switch with ohm meter. Switch tested good.
Any more suggestions. I am going to check some more places for continuity, and physical broken wires, but on my first go over i seen nothing jump out at me.
This one is causing me to miss windrock ride today. (maybe next time)
skinnyr6
Aug 25, 2023 02:18 AM
TheHood
Jul 26, 2015 09:51 AM
Chuck188
Jul 17, 2015 02:45 PM
Unzzy66
Jul 11, 2015 10:01 PM
ranvette
Jul 4, 2015 06:13 PM
