need help pullin fronrt cv on my king
Old Nov 6, 2000 | 07:13 AM
robh's Avatar
are theses like a car and they are held in the diff with a c clip? And if so does it just take some elbow greese to get them out? Any help would be helpfull
Old Nov 6, 2000 | 01:53 PM
Honda4Ever's Avatar
Hi i just change my front right CV boot about a week ago. What i did was i took my hub off. Then theres a big clip where the axle meets the transmission its easy to take out. Then the axle should pull out. Then to take the bearings off you have to remove the circlip thats at the end. Thats about it. If i confused you i'm sorry that was my first time doing that to mine so I'm kinda not specific with the proper wording. K later
Old Nov 6, 2000 | 07:13 PM
frankd's Avatar
you mean pull the inner joint out of the diff?if so they just pop out how i do them is use a bar from the opposite side put it against the bottom of it and hit the bar with a hammer and drive the joint out
Old Nov 7, 2000 | 12:23 AM
ecorman1's Avatar
Rob, this comes apart relatively easy. But the manual recommends some special tools for pulling the axle out of the differential. No, don't hit the shaft from the other side. Do yourself a favor, get a book... It will be well worth the $$...
Chuck, Suzuki KQ 300, GPS & lunch...
Old Nov 7, 2000 | 07:07 AM
robh's Avatar
I got them out already, I just wanted to conferm that they was like a car cvs, and they are. Now I just need to wrestle the diff out of its resting place , thnx guys, Rob
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
jsmit116
Sep 18, 2015 10:34 PM
David Diaz
Sep 8, 2015 04:44 PM
DGNAZ
Sep 5, 2015 09:14 PM
