06 VINSON WONT START
Old Jan 29, 2006 | 11:04 AM
wayoverpar's Avatar
Default 06 VINSON WONT START
went out to start up the vinny the other day, cranked er over and she started up and ran for about 10 seconds and just died, now she wont start at all. Ive cleaned the plug and regapped it made sure its getting spark, made sure its getting fuel, what next, does any one have any suggestions, it really pisses me off because we got 6 inches of snow last night and i really need to plow, any help would be great. THANKS IN ADVANCE.
Old Jan 29, 2006 | 12:06 PM
Dazeys's Avatar
Can't wait to feel that 130 HP at the dunes.
Try a new plug, once they are fouled cleaning won't help.
Old Jan 29, 2006 | 01:19 PM
hondabuster's Avatar
Id start with a new plug too.
If you open the drain on the bottom of the float bowl...does gas come out? You pulled the spark plug out, hooked up the wire, and held the spark plug to the motor, cranked, and saw spark?
Old Jan 29, 2006 | 03:10 PM
wayoverpar's Avatar
YEAH NOT ONLY SAW SPARK BUT FELT IT ALSO
Old Jan 31, 2006 | 08:32 AM
2c3's Avatar
2c3
make sure gas is on and the kill switch on the handle bar is off
Old Jan 31, 2006 | 04:54 PM
Eigeraholic's Avatar
If you have spark and it ran for 10 seconds it sounds like a fuel problem.
When you pulled the pulg was it wet?
Did you pull the plug again after you tried to start it again?
How long was it sitting?
Is the gas turned on?
Squirt some starting fluid in the air box to see if it will start.
Could there be water in the tank? Consensation normaly isn't a problem but water could have gotten in some how.
I'd start with the starting fluid. If it pops move on to the carb.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
